Elmer Fudd
- Joined
- Aug 16, 2007
- Messages
- 14
Lowe's is selling a new Energizer headlamp:
3 AAA (included)
1 watt LED (11 hour)
2 low power white LEDS (50 hour)
2 low power red LEDs (75 hour)
Pushbutton switch
Same general configuration as the previous 6 LED headlamp.
$19.97
Have not tried it yet but it looks to be an improvement over the previous version.
ETA - have opened the package and tried it. Pushbutton cycles 1 watt, red LEDs, white LEDs. Unit seems thicker, pivots away from head to angle light down and expose back of battery compartment cover. Door is not gasketed, but has an ever so slight lip inside and seems to fit tightly. I have used both the 3 LED and 6 LED versions a lot. This unit addresses the lack of a high power beam. I wish it had a different switch configuration, perhaps a different switch for each mode, although this would cost more. The 3 LED slider switch has always looked to me to be a problem to accidentally turn on, although this has not happened to yet. Cycling through modes seems awkward and wastes power turning on the 1 watt LED every time.
The potential weakness of this headlamp might be the plastic hinge/ratchet mechanism. It does not seem very strong. Otherwise first impressions from me are favorable.
3 AAA (included)
Pushbutton switch
$19.97
