One switch for flood - one click low, one medium, one high, one off (timed, so that if you are working in one mode for more than two seconds, it goes immediately to OFF rather than changing modes. One switch for throw - on/off, momentary boost.
your flood operation is perfect, IMO. however, your SPOT/Throw emitter modes leaves a little to be desired, IMO. Why do i make such a bold statement?
ok, it's just my opinion after decades of trekking the forest trails, but here's why...
even the Zebralight H50 with its FLOOD Cree-Q5 at 66lm is not always sufficient for spotting low contrast, faded blazes on rocks and tree trunks out 30+ feet. And even if it is, many will want >2.3h of burntime. Hence, the need for a SPOT. Even if you're gonna' provide >100lm of FLOOD and i can spot blazes 40-50 feet away, it's still gonna' hurt burntime.
therefore, i want a SPOT/throw emitter with other than a similar short burntime. i very rarely need 100+ lumens of THROW output in the forest (other than SAR and maybe mountaineering). i would still suggest keeping a HIGH of >100+ lumens, but we need a lower SPOT/Throw of, let's say 25-30 lumens (out the FRONT, not at the emitter) to have both a long burntime and be able to sufficiently pick out ALL blazes far enough ahead. i'd also say keep a LOW spot/throw output level for times when 5-10 (or even 15) lumens is sufficient for hiking a non-demanding path.
all things being equal, you'll be able to use a lower total light output with the attendant longer burntime if you use a spot beam versus a flood beam. i'm sure that i'm not giving a new revelation here; y'all already know this, but maybe aren't as familiar with how many backpackers will use your headlamp. backpackers, as opposed to campers, love LONG BURNTIMES - it means that fewer, or no spare cells, have to be packed and carried (space and weight requirements).
not every backpacker wants a headlamp solely for in camp task/proximity lighting. i'll stick with a Photon Freedom Microlight, Petzl ZipkaPlus, or PTec Quad for those purposes. longer burntime with some SPOT/Throw output less than MAX is what, i predict, many avid backpackers will want in order to be able to perform nighttime navigation for 6-8 hours, or more without having to change batteries.
also, the lighter in weight the better, so simply adding more batteries (2x4AA cells, or larger batteries, e.g. 4D) is *NOT* the answer. we have to "hump" these cells and possibly spares for a week over rough terrain with the rest of our gear until we reach the next "trail town" where we can discard the used cells properly and purchase new ones. we like carrying less weight whenever possible.
sure, you could use less than MAX flood output for that purpose (maybe???), but you're going to have to have a greater lumen output to accomplish the same level of visibility. hence, a shorter burntime is the result.
flood output is really better for task/proximity lighting in camp and perhaps also for "filling in" when on the move (it would help for those afraid of the dark too).
the spot/throw beam pattern shouldn't be too tight/small however, otherwise, "chicken walking", as i term it, is going to be required, i.e. one's head bobbing about like a chicken walking trying to place too small a hotspot on far away trunks and rocks trying to spot a blaze marking a turn in an unfamiliar trail.
this is not just an esoteric CPF-er talkin' here; i have decades of trekkin' experience and used to do quite a bit of nighttime trekking and orienteering.
i'd suggest that you go over to
www.backpackinglight.com and field suggestions there. a headlamp will be used primarily (i'm guessing) by backpackers, mountaineers, campers, mountain bikers, trail runners, kayakers, etc. - you'll find all of these folks alive and kickin over there. having participated over there for a 2+ years, i can tell you that you'll have many individuals with decades of trekking and mountaineering experience from all over the world responding with suggestions. i'm guessing, based upon knowing them, many will have comments similar to my own, and even some better ones than i've tried to communicate to y'all. the folks there are perhaps equal in education and intelligence to many of the best minds here on CPF, and also equally polite as the best here.
my two shekels.
