NEW Illuminator w/Beamshots & Light Meter Readings
MR Bulk
Hawaii
First off let me say I did not have the time to do a runtime test, but knowing Lambda, if he says it runs up to four hours before dropping into the Moon Mode, I'll put my money on it.
Anyway I was kindly sent one to check out, so here it is with some other 1W Luxeon test partners, from left to right:
Micro Illuminator Prototype
McLux w/BB750, Q3H Batwing, NX-05 optic
MR Bulk's personal Mini LGI
New Improved Illuminator
MR Bulk's personal LGI
None of these lights are "stock", meaning all have been enhanced and/or souped up to some degree. Heady competition, indeed.
Without further ado, here are the beamshots in the same order:
And finally, the test with no subjective influences ("Ooh, but I think I like the beam color better on that one."), the one from which no light can hide, the dreaded LightMan LM631 light meter readings:
Micro Illuminator - 84 lux
McLux - 408 lux
Mini LGI - 555 lux
New Illuminator - 458 lux
LGI - 575 lux
Built to the same high level of fit, finish and performance, this new Illuminator should take us Flashoholics by storm, just like the first one did...
Thanks Kevin, for letting me buy one of these first ones.
Re: Lambda\'s New and Improved Illuminator
Thanks for the kind review Mr. B.
I wasn't sure of the performance on your unit, as you ripped it out of my hands before I got a chance to test it beyond "does it light up". The AS basically cured while in the mail.....
A three hour continuous run time is normal for these units, and much more if used intermittently like most flashlights get used.
Are you keeping busy on your time off?
Hey Charlie,
I would have posted in this forum too, if I hadn't seen this thread - New improved Lambda Illuminator - What's NEW? - so to keep up the whole cross post thing here's the meat of my post, "... the important part, this light ROCKS!!! This is a really nice light. It is very bright with an excellent beam. Workmanship is excellent as it always is with Kevin's lights. I own several Lambda creations and this one was definitely worth adding to the collection. I strongly recommend these lights! /ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/thumbsup.gif I don't which mine would compare to, Professional or Standard, but I really don't think you can go wrong with either. "
Pat
Oops, forgot to include the LINK to order these. The Standard Series is actually in stock Right Now...
