vicali
- Joined
- Feb 13, 2014
- Messages
- 13
New member looking around for info and help selecting my first real light.
I've been using Mags since I was just a little guy- have had a handful of minis, 3C and 3D sizes. I still use my 3D mostly while camping, but the more I look around the more I think I can find something better.
We spend most of our summers at the lake, and now we've got little kids to keep safe and secure I'm looking for something brighter/more throw than my 15year old Mag..
I've been looking around the site for a few days, trying to pick up on brands and models that are good/popular. For this first one I'm more inclined to go with a brand name rather than going custom right of the bat. But I can't promise anything, as a car modder, ham radio guy, photographer, and in general a tinkerer it probably won't be long before I dive in..
X___This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
X____Up to $100.
3) Format:
X____I want a flashlight (hand held/self contained).
4) Size:
X____SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
X____LED (known for efficiency, longevity, and compactness)
X____Incandescent (known for superior color rendition)
6) Manufacturer:
X____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
X____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
X____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
X____I don't know/I need more information on power sources.
X____I don't care
X____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
X____I want to illuminate my entire backyard or a campsite (150-300 lumens).
X____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
X____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
X____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
X____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
X____5-20 yards/meters (check out a noise in the backyard)
X____30-50 yards/meters (I have a big backyard)
X____50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
X____30-60 minutes (I have plenty of batteries just ready to be changed)
X____90-120 minutes (Runtime is moderately important, but still not critical)
X____Very Important (Camping, Backpacking, Car Glove-box).
X____I don't care.
X____I don't know.
X____A simple on-off with only one output level is fine for me.
X____I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
X____I don't know.
14)Material/Finish/Coating
X____I don't care.
X____I don't know.
15) Water resistance
X____None needed
X____IPX4 (Splash resistant)
16) Storage conditions
X____Emergency kit (long standby periods)
X____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
__ Nope
Thanks!
Mike
X____Up to $100.
3) Format:
4) Size:
6) Manufacturer:
X____I don't care
X____I don't care.
X____I don't know.
X____I don't know.
X____I don't care.
X____I don't know.
X____None needed
__ Nope
Thanks!
Mike
