follow this, will take a second to explain it.I was using my new 4d maglite XENON as an IR illuminator. Works GREAT, as xenon bulb makes a lot of IR as a byproduct (you just use a IR pass filter)it was just a tad too heavy, what with the body and 4D cells in there on the gun, naturally. I looked at my older 2c maglite? Hmmm... smaller lighter body, I can make a dummy battery for it easy... ru the wires from the dummy battery to remote D batteries... bang, 4d-mag IR ILLUMINATOR with very little weight up on the gun. Other than threads, of the HEADS, the reflector and everything is the same...MOD went perfect, except for ONE small detail... when i put the "new style" base that holds the 4d Xenon (the one that allows the bi-pin xenon to fit in regular bulb base) there a tiny problem... the HEIGHT of the base is a hair higher. This affects the cam focusing! The bi-pin base rides HIGHER, which wont lt the xenon bulb go in farf enough to make the tight hot spot i need... JUST as its about to focus up each turn? it cmes close and opens back up.seems silly to buy a brand new MAGLITE when i have one already. How to fix this? i tried "shimming" the brass nut that gets pushed down, but... that ruins the camming action.i thought these new bulb-2-bipin bases were specifically to retrofit older lights? Or is the new base i buy in the store different from the base they put in the new 4d xenon?that famous "focus and throw" is what makes the mag so great as an IR illuminator...
