New Sony Rechargeable Battery Has 4X The Lifespan Of Current Lithium Ion Batteries
uninteresting, because 1,1Ah capacity is way too low...if you'll take a "standard" 2,5Ah 18650 and charge it up to 4.1v (or 90%), it will also have a lifespan in the range of 2000 cycles, but with the double capacity...
but thanks for the link! :)
Hmm, that's true, but not many 18650s including IMRs can sustain a 20A continous discharge, and be fully charged in less than 30 minutes, and survive 2000 cycles whilst doing that. ;)
(Long term lurker/reader, but thought it was about time I made my first post!)
:wave:
It's interesting that that did not try to market them as Lithium Iron Phosphate batteries. I'd love to know their marketing spin on that.
The articles from various news sources have all made the "4X capacity" error. It makes you curious about who the original ill advised author was, and who copied his/her work without bothering to research for themselves... :crackup:I doubt more than 4 seperate news sources all misinterpreted the information on their own.
These batteries really are just a wannabe a123 cell. A123's 18650's have over 3000WH/kg power density allowing 30A max current, compared to 1800WH/kg and 20A max current for the Sony cells, AND the same 1100mAH capacity...and they've been out for at least a year.
Just my 4 cents.
I charge mine to 100% in 15min, and I am not even pushing.
Sounds like someone reinvented the wheel here.
100% in 15 minutes? You sure that it's not 99.5%? Sounds like Sony's press release full of hyperbole is rubbing off ;)
I am pretty sure that more products of this kind is a good thing for the market, not a bad thing, even if they are similar. Sony could have an easier type pushing these products into mainstream than other companies too.
These are just LiFePO4 cells, nothing too new. I don't think these will have much use in flashlight applications other than incan hotwires/other fun lights (Databank 70 type) thanks to their terrible capacity.
Re: New batteries from Sony
1.1ah ... bleeeeh
It says that they are LiPo4 cells, so the high load kind of makes sense. However, the capacity is pretty low...
