That's funny. I'm keeping a couple or few in the original low light format for exactly that reason--very light retro.I'm thinking of converting some of my (10) Cree'd Elly's back to original led.
Cree'd just too bright for some night-time wanderings.
Good job. Amazing beam for the $, eh?Originally Posted by axotlatls: I did snip the blue wire and just did a jumper between the screw and the (-). For $9.49 plus whatever the 14500 cost, it's a bargain and a half!
Yeah. IMHO it gets even better using Kai's 10 for $10 optics in there. The thing project a wall of light that is more useful IMO. Once I improved the contacts and grounds it seems to running fairly strong -- draws about 1.4A from a NiMH cell and delivers healthy output.Good job. Amazing beam for the $, eh?
2xTrinity said:Yeah. IMHO it gets even better using Kai's 10 for $10 optics in there. The thing project a wall of light that is more useful IMO. Once I improved the contacts and grounds it seems to running fairly strong -- draws about 1.4A from a NiMH cell and delivers healthy output.
selfbuilt said:Just got my Elite from Kai yesterday ... and it doesn't turn on. Exchanged switches with another Elly, and confirmed it's not that. Looks like the problem is at the emitter - they just tried to extend the solder blob from the blue wire at the (-) terminal so that it just touches the aluminum frame. Obviously didn't quite make it - this is even worse than the old method of running a wire to the holding screw.
I would fix this myself with a proper jumper, but there's a bigger problem - the head (with lens/reflector) won't screw down. The head fell off as soon as I opened the package - seems to a thread depth issue on the body. The new head screws on fine to either of my old two Elly lights, but neither of those heads will catch the threads on the new Elite. Tried thread tape, but no help - won't screw on, just wobbles loosely on top of the emitter. :thumbsdow
Sent an e-mail to Kai last night, I'll let you what their response is. I suppose I could keep it for spare parts ...
I installed them in all my Elites (yes they do fit) In fact an even wider optic could theoretically fit (and allow for a little bit better throw, though I like the semi-flood beam), but the elly head is the perfect size for the optic inside the holder, without needing any sanding. The fact that the threading is so deep means you can snap the optic into the little holder, set that on top of the emitter, then screw the head down until it all comes together.Do they fit inside the Elite head?
2xTrinity said:I installed them in all my Elites (yes they do fit) In fact an even wider optic could theoretically fit (and allow for a little bit better throw, though I like the semi-flood beam), but the elly head is the perfect size for the optic inside the holder, without needing any sanding. The fact that the threading is so deep means you can snap the optic into the little holder, set that on top of the emitter, then screw the head down until it all comes together.
