The Brown Truck left two packages yesterday, both from Bison/TMX :D
Machine work on the parts is superb ... both sides of the back plate have been Blanchard ground (by a rotary surface grinder) so that both sides are dead flat & perfectly parallel. The back surface of the chuck received the same treatment. Since my spindle nose is also Blanchard ground, there should be nearly zero axial run out ... although the indicator showed .0001"
Close up view of the back plate:
Before mounting the back plate to the spindle nose, I pulled all the locking cams for cleaning, deburring, and greasing. No sense taking a chance on a leftover piece of grit scoring one of the new locking studs. Two of the studs had to be backed out one turn for proper cam engagement, but nothing else. A piece of Thomson linear shafting was used to dial in the radial run out ... about .0002" to .0003" TIR - well under the .0004" that Bison guarantees :D
I rechucked the 2" bar of 1144 Stressproof and took a couple of very light cuts with the end unsupported. The DCGT-32.50.5 from Rani Tool was used for this test as it is super sharp. Where the diameters had showed .0002" difference before, the DCGT left a surface that had only .0001" (or a little less) difference from end to end.
Even with a decent sized part in the chuck, there's still room for more:
On edit 04-19-2010 - the 4-jaw Bison came on the Brown Truck ... the driver seems a little weary these days ...
Those are the photos from the eBay listing so they lack some detail, but the chuck has almost zero wear. Purchased from Rochester Machinery Suppliers
http://stores.ebay.com/ROCHESTER-MACHINERY-SUPPLIERS-INC
I phoned last week & spoke with a guy named John - who owns the business. The UPS calculator on eBay showed $88, which he said was way more than it should have calculated. I had John ship & bill to my UPS account & the cost was $26.27. The chuck arrived in a custom built plywood box, 3/4" thick, screwed together on all sides & strapped with steel banding - my kind of shipper. A superb company & person to deal with :)
