Newbie needing directions
Konalover
Hi everybody,
I have been looking around as a visitor on this forum for quite a while now and am getting to the point where I would like to build something myself.
I have seen on another forum (MTBR) the build of a Culite dinote style light.
http://forums.mtbr.com/showthread.php?t=580785
Has anybody outhere tried that build ? Is it do-able for a newbie?
Thx in advance
It looks easy enough if you can solder and use a screwdriver.
A couple of interesting items to consider:
http://www.lux-rc.com/view.php?p=content/magazine/L31_a_real_nano
and:
http://www.cutter.com.au/proddetail.php?prod=cut968
and:
http://www.cutter.com.au/proddetail.php?prod=cut969
out of stock but uses the nice tight Regina optic:
http://www.cutter.com.au/proddetail.php?prod=cut992
These combine driver and LED on one board and will fit the pipe light. Should make your build easier to do.
Tip: Decide on the type of riding you do and the type of beam you need, then the cobination of LED and optic to do that. You will be happier with the result IF you take a good shot at what you need.
If the Regina and an XP-G is it you may need to go on backorder, and wait but you will be glad you did.
Hi BrainMC,
These look very nice ! Will have to take a closer look at those.
Thx for the tip
Another question : can you paint (spraypaint) such a light or does it harm the thermal capacity of the copper?
I would like to paint it to make it look nicer.
Thx
Thx
Can you paint it? Yes.
Will it affect thermal transfer to the air? Yes. Not a huge effect though.
It will not affect thermal transfer inside the light from the LED to the copper under the paint. As I understand it, unless you use a thick insulating layer of paint it has a minor effect, the order of best heat trasmission to air is (from my reading and I do not remember seeing actual numbers attached):
Anodized aluminum
Aluminum
Copper
Paint
The differences in the top three are small and overshadowed by the small changes in the size of the sink, ambient temperature, or air speed over the light. I would think that a thin layer of aluimum paint (has metal in it) should be better than flat black paint (radiates heat well think stoves), should be better than say a thick coating of white enamel or epoxy.
3 options other than paint:
1. Make the light with aluminum electrical conduit or similar pipe. There is a thread of an aluminum CuLite on MTBr somewhere. You can opt for a brushed finish, polish it to a mirror finish, or spend the money to anodize it (another thread on that in MTBr). If weight is an issue for you this is a great option if you want a light body to match other components. Warning: anodizing apparently is as addictive as making lights.
2. Make the light bigger so it has more area in contact with the air to compensate for the paint. Longer helps the O ring mounting method too.
3. Polish the copper regularly to keep that bright gold-orange color not the dull burnt orange to bronze it will tarnish to. A little oil or wax after the polishing (residual in most polishing compounds) will slow the tarnishing but I am not sure how that compares to a coat of paint. I'd guess a LOT thinner, so negligible.
Speaking as another noob, thanks for starting this thread Konalover, as it contains so very useful links.
I currently have two Niteflux VisionStick lights for my bike, one an Enduro 8 and the other a Halogen 10. I got the halogen one second-hand after discovering this forum, with the intention of finding out how to replace the standard halogen with a high-output LED emitter. Having seen the link to the Cutter Electronics MCEQUICCpower light engine I believe I may just have found what I'm looking for, as long as it will fit indside the standard housing of the NiteFlux.
I'll start a separate thread about this when I get a chance so I can ask some questions without hijacking this thread more than I have done! :sssh:
