Nichia 183 Mule
Tekno_Cowboy
Minnesota
Finally finished my first home-brew light, a Nichia Mule-type light.
It's running a Nichia 183 High-CRI emitter, SW45 tint bin. The emitter is direct drive at the moment, but will have a resistor installed soon enough. The light is made for an 18500 Li-ion cell.
The best part about this light is that I made use of a failed prototype :devil:
The o-ring shouldn't show once I have the resistor installed and can tighten the pill snug to the UCL lens.
This sucker was a huge PITA to solder. I'm thinking next time I solder the wires on before I glue down the LED. :ohgeez:
Disassembled
Nope, I don't have an 083 to compare it to.
I could maybe send it Don's way if he'd be interested in taking a couple shots.
I think I've read that you want to attach a LED to the heatsink before soldering, because the solder heat can damage the LED and the heatsink helps pull it away. It also makes it more difficult to solder. :nana:
Nice looking light. :)
Woo-hoo! Nice first light from scratch, Travis!
How much current are you shooting for when you add the resistor?
