NovaTac 120T Triple Nichia 219C - H17Fx - 18350 - Tail Clicky
CRX_
Scotland
I notice a few NovaTac fans on CPF so thought I would post my latest 120T build here too. :thumbsup:
Stock Light:
Low - 40lm
High - 122lm
Had a bit of bother getting the old driver out.:eek:
Aluminium heatsink filed into shape to fit the fit the internal contour of the flashlight head and make contact
with pill insert, potted in place.
22mm brass tube cut & filed down to fit inside the aluminium pill with brass mounting ring inside for 17mm driver,
all soldered to contact board.
2mm thick aluminium disc installed in pill. Copper contact soldered to driver board.
Another 22mm brass tube section cut for optic/ MCPCB surround to support O-ring, fitted in place.
Copper tape around pill for snug fit.
Cut out slot for new clicky switch in switch board, soldered in place.
Brass ring soldered onto board, spring attached, wire bypassed, potted.
Felt lined battery tube. Reassembled.
NovaTac 120T - Triple Nichia 219C 5000K - H17Fx - 18350 - Rv Clicky Sw - 2300lm.
Triple Nichia 219C D320 5000K on 20mm MTN DTP MCPCB
10507 Carclo optic
22mm x 2mm ARC glass
Cyan GITD glow disc
Dr Jones H17Fx driver
Reverse clicky tail switch
Lockout-able
18350 cell compatible
Length – 86mm
Width – 26mm
Weight – 96g (with 18350 cell)
Setup:
Mode 1 - M/L - Level 2 - 0.1% - 3mA
Mode 2 - 35lm - Level 12 - 3.0% - 95mA
Mode 3 - 260lm - Level 18 - 25% - 760mA
Mode 4 - 1010lm - Level 22 - 100% (8x7135) - 3040mA
Double Tap Mode - 2300lm - (Level 24)
Nitroz
Monroe
Nice work! I have a few NovaTac and HDS lights that have been sitting around with different issues that I have plans to do this to but have been to busy with other modding.
The original design is great but I always hated the signal spring being so temperamental and not being able to use 18350 batts.
jon_slider
Nimitz68
USA
PM sent regarding the NovaTac 120T - Triple Nichia 219C 5000K - H17Fx - 18350 - Rv Clicky Sw - 2300lm. Beautiful!
Nitroz
Monroe
Here is a solution.. CRX Style: (click pic, it links to the original thread)
While that is a very cool implementation I like this mod much better, and 2300 lumens is insane! I know it is probably ten seconds but hey cool anyway.
ven
Manchester UK
WOW CRX, amazing........................no other words. I defo need a triple tac at some point haha
CRX_
Scotland
Quick test:
0s - 2300lm
30s - 2117lm
60s - 1827lm (Hot!)
Nitroz
Monroe
Quick test:
0s - 2300lm
30s - 2117lm
60s - 1827lm (Hot!)
That's awesome!
I think I'll machine a new pill from copper even though it will still saturate from heat it will take longer.
Nitroz
Monroe
You're the infamous "CRX" from BLF with all the crazy mods are you not?
