NiMh and Nicad battery charger
Numbers
Long Island, N Y
Can anyone recommend a high quality battery charger for NiMh and Nicad batteries. I need advice on a charger that can be used for both types of batteries.
I need a recommendation on a charger that will do aa and aaa size batteries, and a recommendation for one that would do all sizes of rechargable batteries using battery holders, as well as battery sticks such as the one in the SF8AX. The ability to charge cells individually rather than in pairs is also important for when the need arises.
The only experience I have had so far with chargers is with the Maha 204f (recent digital camera purchase) which may get the job done but in my opinion is not high quality (1st one I ordered did not work, second one blew a battery at the end of the charge cycle, on my third now which keeps on charging forever, I dont think it is detecting voltage drop at what should be the end of the charge cycle).
Help Please, Thanks
the alltek 5798 looks like a decent charger...not as fast as some but with the all important microcontroller (NOT a timer) and the nice conditioning feature...too bad you can't charge a single battery if you wanted to, not everything uses batteries in pairs...
Also...
Rayovac chargers designed for their "Renewal" alkalines also charge Nicd and NiMH. Microprocessor controlled, automatic recognition of battery type. They are not "fast chargers, though, and no conditioning feature. (you can always run your bats. down in a flashlight before recharging to condition them). http://rayovac.com
I bought the Rayovac PS3 charger for $15. It does AAA-D batteries. 8 AAA/AA at a time, or 4 C/D. It has 4 separate charging circuits.
Originally posted by Al:
[QB]Also...
I bought the Rayovac charger for my renewal alkalines & thought it would be great to be able to do my NiCads too. Problem was, after 3-4 days, some of the NiCads were still chargeing. It had them over 1.4V & still chargeing. I just use it for the renewals, as I don't feel comfortable with its auto recognition system. TX
Tested my ps3 with 4 1600mA NiMh's that had only self-discharged for about a week ... after 3 hours ps3 was going and going and going ... batteries getting hot.
Took 'em out and put 'em in a MAHA 2040f ... after 5 min. the MAHA shut off (to trickle mode) .. Think I'll restrict the Rayovac to the Renewals also.
I haven't had any problems with my Rayovac PS3 charger. I've used it on rechargable alkaline, NiCD and NimH. The batteries barely get warm.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Al:
Sent an e-mail to [email protected] advising them of this ...<HR></BLOCKQUOTE>
I did this when I had the problem with mine. I got a reply that sometimes it takes awhile to charge..........but 3 days! Since the expensive chargers don't do the "renewables", I have my doubts that this $10 will handle all 3 types. TX
Picked up the ccrane quickcharger and am putting it thru it's paces ... seems so far that it does as advertized, interesting though that the unit automatically goes into a "conditioning" cycle if the battery(ies) are below a certain voltage level. Does this regardless of chemistry (NiCd or NimH). Has an override button to get around this, however.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR> the unit automatically goes into a "conditioning" cycle if the battery(ies) are below a certain voltage level. <HR></BLOCKQUOTE>
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR> no conditioning feature. (you can always run your bats. down in a flashlight before recharging to condition them). <HR></BLOCKQUOTE>
Noticed the comments about conditioning. Everyting I've read says that you should not condition NiMH batts. It's more destructive than productive. You especially don't want to run them down in a flashlight or any other device that doesn't have a low voltage shut off.
Personally, I've been using the Maha charger for a few years with great success for my digicam batts. Would like the ability to do one cell at at time, since my Motorola Talkabout radios work on 3 AA's.
First quote (in context) made it clear the user could get around this automatic feature where NimH's were concerned ... second quote (in context) was discussing BOTH chemistries ... should have made it clear that the NiCd's could be "run down" for "conditioning" :-)
At any rate, the Ccrane charger seems to accomplish the same as the MAHA 204F, but heat is noticably absent with the Ccrane.
Picked up this info at this site: http://www.greenbatteries.com/documents/Battery_FAQ.htm#alkaline
Do NiCd batteries really have a memory effect?
Answering this question is a sure way to start a flame war on the internet. The simple answer is: Technically speaking NiCd batteries do not have a memory effect. However, they do suffer from a voltage depletion phenomenon that most people call the memory effect. So practically speaking, NiCd batteries do suffer from a memory effect, even if it is not technically correct to call it that. Fortunately, the voltage depletion effect is reversible by conditioning NiCds.
If you use NiCd batteries you should be aware that most the problems experienced by NiCd battery users are not due to a "memory effect" but are due to overcharging. Overcharging is usually caused by poorly designed first generation battery chargers. These chargers continue to deliver current to the batteries even after the batteries are full charged. "5- hour" and "8-hour" chargers can easily damage NiCd or NiMH batteries.
The big difference between voltage depletion, the "memory effect" and damage caused by overcharging, is that reduced capacity due to overcharging is not reversible.
Do NiMH batteries have memory effect?
No, NiMh batteries do not have a memory effect, but strictly speaking neither do NiCds. NiMH batteries can experience voltage depletion similar to that of NiCd batteries, but the effect is much less noticeable. To completely eliminate the possibility of NiMH batteries suffering any voltage depletion effect some manufacturers recommend an OCCASIONAL, deep discharge of NiMH batteries followed by a full recharge.
<HR></BLOCKQUOTE>
Conditioning is nothing more than permitting the cell to discharge to around 1 volt. If one had to be cautious, making sure they are recharged before they ever reach that state in order to avoid "conditioning", then NiMH is a poor substitute for NiCd. I've been nearly depleting my NiMH cells for around 3 years and they are holding up as well as when they were new, if not better.
By Empath:
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Conditioning is nothing more than permitting the cell to discharge to around 1 volt. If one had to be cautious, making sure they are recharged before they ever reach that state in order to avoid "conditioning", then NiMH is a poor substitute for NiCd. I've been nearly depleting my NiMH cells for around 3 years and they are holding up as well as when they were new, if not better. <HR></BLOCKQUOTE>
Same here, and I found that my cell phone NiMH battery responds better to a charge if I wait until it's almost depleted before charging.
Although it is a long time ago that you posted this question:
Conrad recently develloped a high quality battery charger that meets your requirements: Voltcraft IPC-1.
Help Please, Thanks
