jchock
I've had a BC 900 (v. 32) for over a year or so now as it replaced my Maha C401FS (that fried batteries when the power supply started making whining noises) and my older Ray-o-vac PS4B 1hr house burner.
The Maha killed all of my 2100 Sanyos (16 of them), my Nexcell 2100 set (4 of them), the ROV PS4B killed all my 1800 GPs (16 of them). By killed, I mean either they wouldn't hold a charge, or they wouldnt' charge on the chargers at all (blinking red lights).
So I started off with (new) 16 Duracell 2650s and four Sanyo 2700s in the BC-900 last May (Sanyo)/June (Duracells). Somewhere I lost 4 Duracells, but I still have the other 16 batts.
In the past two months, I've noticed that the batteries just don't hold a charge. As in, if I take it off the charger, and let them rest, the next day, they're not 1.4V (as it said on the charger when I took them off) but 0.88-0.95V. If I take them off the charger, "fresh" they won't power my lights or camera flash. The lights won't turn on (where they're bright if I use AA alkalines or lithiums) and the flash (if it powers) just whines, but never seems to charge the flash circuit. Sometimes they won't power my portable CD player.
The readings on capacity have changed as well. When I first get the batteries, I write their charging capacity (to match them) after I cycle them a few times. The Sanyo 2700s for instance read about 2750-2790 mAH on the BC900 when I first used them. More recently, one won't charge at all (null) and the other three, when charged at 200 mA and at 1000mA will read about 3300-3400mAH. That would be a great amount, except I think either the charger is broken, the charger has killed the batts, or the batteries are somehow discharging over the 18 hours on the charger and that's why they end up with such "fabulous" readings.
I have generally charged the batts at 700mA to 1000mA if only because I would really need all 16 batts charged for the weekend to power the camera flash and that was the fastest way to go... More recently I've tried the 200 mA setting, but I haven't seen any revivals or improvements...
I doubt I've charged each battery 100 times, let alone "thousands" in the past 9 months, so what have I done wrong to make these batts the way they are? Is it me or the charger? If one kills $50 in batteries every 6-8 months, is it really worth the infrastructure in chargers and batteries?
Any suggestions on where to go now?
Thanks!
Thanks!
