nite tracker and the responder
rajanf1
CAN
Hi,
Has anybody used the nite tracker 4AA light? They are from Koehler-Brightstar and seem to be for industrial use. Are they basically the same as the 4aa responder? Can the nite tracker take pr based lamps without crushing the NiMh batteries?
TIA
This is the first I've seen that light.
Does the Responder have a problem with NiMH?
[ QUOTE ]
[/ QUOTE ]
Yes, when you overdrive a 3C/D krypton bulb, it's blinding and the focussed spot is so tight all you can see is the top of the tree three blocks away! /ubbthreads/images/graemlins/blush.gif
