Yeah, the EX11.2 isn't completely without issues, but I really like mine.QQ- so I'm considering a D11.2 versus the D10 battery vampires. Are you saying I should wait? It seems I had good luck, at least thus far with my EX11.2.
The only thing I notice after playing with mine quite a bit is that the ramping is not smooth with 16340 batteries (keeping a CR123 in it for now). Other than that, the light is awesome so far. The clip is the best I've experienced so far too... it's a worthwhile upgrade.
Have you experienced switching to low when you actually need to switch it off instead?
I'm with you, DHart. I trust NiteCore is paying attention and will tighten up the QC for their next releases. NiteCore, you succeeded with the D10, now take us to the next level!
The D11.2 also looked very appealing to me, but I won't be buying it either. I think I will just pay 20 more bucks and get the V10A. Pity too, because on paper the D11.2 is exactly what I am looking for in an AA EDC. A rugged, ramping light with an indestructible switching mechanism. That doesn't seem to the case in practice.
There's a whole lot of good competition in this space and no reason for someone like me to have to play the lottery to see if I get a good one. There's just too many other lights out there that I know for a fact I'll get a good light!
But someday maybe Nitecore will get its act together and I'll try the D12 or whatever the version they get right 100% of the time is. And then if it's good, I'll get the Exx version too
My only experience so far is with disposable lithium batteries, with which my D11.2 performs very well, the ramping is smooth and easy to adjust. I hope this helps.Can anyone comment on how smooth the ramping action is on their D11.2/EX11.2 using both standard AA/CR123A and 14500/16340 4.2V? Ramping is smooth using the 3.0v battery in my EX11.2, but it isn't smooth when running 16340. Just wonder if it's normal... otherwise my light seems perfect.
Unfortunately after the first few days of trouble-free performance, the problems continue. After tightening the loose LED module the light started to behave funny, like switching to a lower level or flashing instead of switching off, not turning on at all, blinking once instead of turning on etc. Following the advice in an older post, I disassembled the body and found some dirt between the piston and the external shell. I washed them both with warm water and soap, dried and re-lubed them with Nitecore silicon grease. This seems to have solved the problem so far. But I must admit that this is not what you expect from a brand new $60 flashlight... I own 6 high quality flashlights and this is the only one that has had such issues.
I've a bit of christmas money left over and I'd like to update my EDC light. I want a 1AA compact light to replace my Cybalite Orion (which is still going strong BTW). So hopefully no bigger than that light, which is 96x20mm.
Either the Nitecore D11.2 or the EZ AA R5 look good in some ways. But I've some questions which hopefully you guys who own the things can resolve:
The D11.2 has a safety lock-out to prevent accidental switch on. This is an important feature in my view. Also it is said to run on Ni-MH, another important feature to me.
The EZ AA R5 apparently does not have these features according to the Nitecore website. Or does it?
The problem is that the EZ AA R5 is significantly less expensive here in the UK (£39.95) versus £49.95 for the D11.2, even tho the EZ AA R5 is brighter. I don't want to spend nearly £50 but I might spend £40, if it has the features I want. Can anyone help?
