Badbeams3...does your d-10 flicker when your
ramping the lamp up or down?
My D10 on a regular battery makes a horrible buzz at max. On the 14500, there is no buzz at max. On max the light reaches 106 degrees at 2 minutes.:thinking:
have you tried the 14500 on another flashlight?, maybe its something in the battery that is going on.
if not, contact 4sevens, he should be able to help you.
It would have to be the charger because it is happening to both of the new AW's I got but they came charged and have not been on the charger for more than 5 minutes. I would find it hard to believe that i received 2 bad batteries on the same order but stranger things have happened.
4sevens contacted....
