Nitecore NDI and D10 R2, differences?
ohwhyme
Whats the difference between the nitecore ndi and nitecore d10 r2? It is just the ndi is brighterm, a little bigger, a little more expensive and has a strobe? Do any of you actually use the strobe a lot and what for? Thanks.
Apart from the strobe, the main difference is in the way the adjustable levels work.
If you like to set your adjustable level once, or relatively infrequently, the NDI will work better for you.
If you will be adjusting your light level frequently (to suit your working conditions for example), then the D10 would be a better choice.
The NDI is a two mode light with a forward clicky, the D10 is a single mode light with a piston drive.
The D10's PD is silent and smooth. It really is a different feel from the usual clicky switch, I like it a lot. Also of note: one can use the D10 as a twisty if desired, works great either way. The knurling feels very secure in the hand. I haven't tried a NDI but its knurling doesn't look quite as pronounced in the photos.
I've EDC the NDI since nitecores original thread offering the NDI's for special sale...
-I can say the strobe probably isn't effective tactically since it's rather slow.
-The knurling isn't quite as aggressive as it could be, but far better than solarforce products.
-It's a bit longer than the D10
The reason I bought it was it's incredible multi-cell capability and it's compactness--at the time of release it was the most compact forward clicky AA light available, the the only one able to regulate on 14500 cells.
HOWEVER, I believe the D10 will be superior now, because it uses a processor to regulate the voltage and output. The NDI had great regulation on 14500 and it had AA Alkaline capability but the Alkaline and NiMH regulation weren't nearly as good. The D10 will regulate very evenly throughout the battery's runtime.
One nice thing about the NDI was dual modes. Basically you have tactical level brightness, which is useful if you have a house invader for example. The second mode, which is user definable is best for either medium or--my personal favorite--really low. I used the really low setting when I was an LP to investigate shoplifters deep pockets/cavernous purses etc. because I didn't want the beam to bounce back up and blind me.
Good luck!
