Cavelightchris
- Joined
- Dec 5, 2007
- Messages
- 69
I just went to Princeton Tec's website and I was looking at the Corona, and I noticed that they only list alkaline and lithium under batteries.
Could this be because it only uses 3AA's, and they are afraid of it doing the same thing the Myo XP did; having the headlamps power wire melt on you.
Or maybe it's because they know it won't be as bright as it should be. Well I will just have to call them and drill them about why this is so.
At least under batteries for the Apex, it still says alkaline, lithium, NIMH rechargeable. But that is definately because it uses 4 batteries, and the voltage is current regulated and stepped down. So in that case there is no reason why you shouldn't be able to use rechargeables; it will be just as bright when using them, and the power cable had to be designed to flow up to 9 volts (that is what Princeton Tec said the maximum voltage is), and so I guess it has a pretty beefy power cable compared to the Myo XP.
Did they ever find out what exactely it was about rechargeables that made the Myo XP's wire melt? I have read plenty of theories on why, and developed some of my own, but I never found out what was causing it for sure. You would think some electrical expert on here would have identified the cause by now.-'
Anyway, back to the Corona: My friend bought one on ebay for $25 before shipping, and it impressed both my brother and I very much. It was so bright (65 lumens), and it had so many modes that were quick and easy to use; press one button to cycle through 8, 5, 3, 1, and flash LEDs, and press the other button to change any one of those modes(except flash I think) from low to high. Even on 1 LED on low, we decided it was plenty of light to navigate through a cave and find your way out, and with a runtime of 160 hours, you would be really well off, and I'm sure that 160 hours is for 1 LED on low. Well my brother had to have one, so he paid $40 before shipping for one on Amazon.com.
I also planned on getting one, it has an amazing flood on max, and it was so much flood it could even brightly light up the ceiling of a 67 foot pit cave. But now that I found out it shouldn't take rechargables for some unknown reason, well I'm not impressed. I don't like using alkaline or lithiums for two reasons, that would cause me to spend more money on batteries when I already own eneloops that should last for 1000 charges(according to the manufactor), and I also like to not contribute to buying batteries like that for environmental reasons. In fact I am always taking in peoples alkalines so that they won't throw them in the trash. I am up to like 1000 of them now, and really need to find a place to properly dispose of them, but for now they can just sit in the garage, no biggy.
