noob question Q5 driver
csinsc
Hi,
I bought the 3AA (4.5v) version of the Northern Tools led light... the light seems to be ideally suited for modding.
http://www.northerntool.com/webapp/...stomer driven-_-Recently Viewed-_-Search Page
I want to place a Cree Q5 star board in there but which driver should I use?
One other questions I have are:
The driver boards, when you use them with 2 cell batteries, do they bump up the voltage (i.e. to 3.7 volts for the leds)?
Or is the only requirement for the led to conduct simply the .7 volt break-over voltage?
I guess my questions are about what functions the drivers perform, voltage/current regulation?
Thanks,
Chris
A driver changes the input voltage and changes it to the voltage the LED needs.
With 3 AA batteries, the light probably has a resistor in there. If you want to use a driver, look at a buck driver(like this) if you want to use 3 AA batteries.This boost driver might also work but then it will be direct driving until the batteries get below the Vf of the LED.
If you use a D cell(a bit larger then 3 AA cells might fit), use this driver and also get 5 modes with your light. If you 3AA batteries, this driver will give more light and also 5 modes, or this one if you use rechargeable batteries(3 modes and brighter die to more current).
About how it works, all I can do is point you over to the Wikipedia link about voltage regulators and DC-DC converters.
From various posts I've read, three cells might not give you enough volts for a Q5. Don't know what you mean by a 0.7V break-over voltage. All white LEDs need at least 3V to get any reasonable light out of them.
Do you already have a Q5, and if so, what operating voltage does it need for the current you want to run it at?
Hi,
They provide a constant current. The LED, not the supply, establishes the voltage. The driver does have to be capable of supplying the required current into an approximate 3.7 volt load.
A silicon diode has a forward voltage of approximately 0.7 volt at moderate currents. LEDs are not silicon diodes; their forward voltage is much greater. You can find graphs of the voltage vs current of typical LEDs many places in the CPF archives. I posted one here.
Current regulation. See the second posting down from the link for a description of a current source.
c_c
