Gryloc
Hello all. I have done a few searches and feel semi-confident on attaching li-ion cells in parallel now. I understand that the cells must have voltages very close from one another before connecting them in parallel in their intended application (within 0.5V from each other -thanks SilverFox) to keep in-rushing current to a minimal, but it is just best to charge them fully before hooking them in parallel. I understand that the cells will automatically balance each other as they are charged. Even after they are disconnected, they will continue to balance each other.
I feel better after some searching on the CPF, but I still have some further questions to sooth my mind. I am thinking about making a battery pack with either 2 C-sized li-ion cells (available at DX), or 2 D-sized li-ion cells (available at KD), in parallel. I have protection circuitry (3.7V, 8A), fresh cell wrap for both sizes, thin kapton tape (for insulation), and some copper tape for connecting the cells. Should I use one protection circuit per cell, or can I use a single protection circuit (that can handle the current) for both in parallel?
Can a "dying" cell that seems to lose it's charge drag down the other cells (due to the continuous balancing) to a point where the battery pack would be a safety concern?
Finally, a bit off topic though, would two C or D cells (li-ion) face much voltage sag when there is a current draw of about 3A compared to 3 series connected C- or D-sized NiMH cells? I want to find the best combination of cells to power a 3A load without too much sag (which would reduce current dramatically with a DD LED load). By the way, to maintain this 3A load, the cells must be operating at ~3.5V (the Vf of my Seoul P7 at 3A), so maybe it is good to have some voltage sag. Is this correct? In a Maglite body, there will be a bit of resistance, which may drop the voltage down to the required level at high currents. I can always add a resistor in there, too. Am I in over my head, and should I just use regulators with 2 series connected li-ions?
Thank you for the help!!!
-Tony
-Tony
