Your best bet is to find a KL1 and dissect the optic. Mod the KL1 with Seoul and McR-20S while your at it and use the TIR on your Nova...:devil:Where can one get it? (optic)
is it a direct fit or do you have to mod something else inside?
Would the 120P be a feasible host for the high-CRI Nichia 083? In the Sundrop, the LED looks quite large, but that could just be the magnifying effect of the lens.
If it worked, it would obviously not be able to achieve anything like the brightness of even the stock LED - perhaps you might get ~50 lm - but it would be very good to have the true color rendition of the Nichia 083 combined with the multi levels of the Novatac.
I don't think replace the reflector with optic on Novatac is a good idea.
If you open it up you'll see the pill is narrower than inner tube diameter so doesn't make contact with sidewall well. It is however pressed tightly against the aluminum reflector, which act as the middle man to conduct heat away from the LED/module. Change that to optics you take away the middle man, so now the heat has to go through the air barrier between pill and sidewall.
Not sure if this is the correct area to ask this question. I was wondering if there are any mods for the novatac 120p to get more throw!?
