shankus
Today, I received my R2H high dome from the Sandwich Shoppe. Earlier this evening, I soldered it onto a MadMax+ sandwich, with some heatsink grease underneath. All went well. /ubbthreads/images/graemlins/thumbsup.gif
First, the color. The R2H is so very white. It is on par with my Lambda Megaclops SE (5 watt side emitter, driven @ 10 watts).
The combination of the high dome & NX05 is very focusable. The beam in mine, changes like this:
In the tightest spot, the spot is about the size of the spot with a low dome & NX05, except, it doesn’t blend into the corona so gradually, it is more defined. Around that spot, is a squarish, slightly star-like artifact, that has a very light blue tint (from what I understand, this is an image of the die). Around this, is a large, dimmer, white corona, about twice the size of the normal low dome & NX05 corona, but darker towards the middle, sort of a white, ringish corona.
As I defocus, the spot grows larger, while at the same time, the corona becomes smaller & brighter. The squarish artifact disappears.
This happens until the two kind of equalize. The flood ends up being about the size of the corona with a low dome & NX05, it is not artifact free, but is fairly regular, and definitely better that that of a Mag-Lite flood. It's negligible irregularities are only apparent on a white wall, not in normal use. It's is very serviceable. /ubbthreads/images/graemlins/grinser2.gif
Now, in comparison to my other MadMax.
The two lights:
1. MadMax+ Q3L low dome w/NX05 (white w/violet tint).
2. MadMax+ R2H high dome w/NX05 (stark white).
Shining both combinations at the ceiling, and checking the amount of ambient light, seems to show that the high dome combination is not as bright as the low dome combination.
Also, when shined at a white wall, the high dome combo seems dimmer than the low dome. I think a light meter would confirm this.
I don't know what to think of this/ubbthreads/images/graemlins/thinking.gif, because in any other use, the high dome combo seems brighter.
Outside, I shined the low dome combo in the yard. Then when I turn on the high dome combo with the spot, it makes the low dome appear dim in comparison. I can move the high dome spot all around in the light of the low dome, and the high dome spot overwhelms it. /ubbthreads/images/graemlins/eek.gif
As I change to a flood, the flood beam of the high dome is as bright as both the spot & flood of the low dome. I even tried this with my one cell Mini-Mag, and vs. the two cell low dome, the flood of the high dome is brighter.
It seems the same when I shine both in the treetops, or out into the desert. Could it be that it seems brighter only due to the color?
I don't think the NX05 gets the most out of the high dome, and again, I think a light meter would confirm this, but I do like this set-up a lot. I like the stark whiteness of the luxeon, the definition of the hotspot, and the focusability.
All of this playing was with fresh NiMH in each light.
I don't know if this high dome MadMax+ will stay with the NX05, or go with the McFlood I just ordered (hasn't come yet). /ubbthreads/images/graemlins/popcorn.gif
More on that when I get it.
The two lights:
