Phaserburn
Has anyone successfully replaced/used a brighter bulb in the BD Supernova? Is it true this is a 2.4V bulb? BD says that the Superbright bulb will not work, so it must be a different voltage.
With a Willie Hunt regulator, if a similar voltage bulb can be found that draws more current, would a brighter light be the result? I am thinking of using NiMH AAs to allow the extra current if such is possible. Bottom line is, I'm trying to get the incan on the Supernova to live up to it's name! The stock bulb isn't horrible, but try I must...
