Old cr123
staghater
Hi,
just a quick question regarding old cr123 primaries.
Have a bunch of batteries that still work even they are best before 2017 :O
Is it safe to use them in 1 cr123 lights or to ditch them?
As far i noticed on forums, double 123 batteries are not safe to run if they are old or mismatched but am i safe with single old cr123 in light?
I have tons of ancient CR123A's I'm always going through before the newer ones. I just make a habit of checking their voltage and knowing where they originally came from to decide if they are safe in multi-cell lights. And I only use quality CR123A's. Not that most aren't nowadays, but there use to be some real questionable ones out there and I'm sure still are.
I have some 2011-2013 dated cells with the old label and I just ran them on my ZTS tester (tests the cells under load) and was surprised to find them at 80% capacity.
I intend to use them in my SF E1B or Nitecore EX10.
Did they come in boxes like these? :giggle:
    370.7 KB
They have a pinkish hue on the wrappers instead of the normal full red if you ever open one up, and a SUREFIRE font like nothing you will see on any batteries newer than 2002 production or so. 2001-2013 expiration sounds about right then. Around 2003-2004 they started with the different old school font and full red wrappers.
I must have used the older cells. All I have left are 2006 production cells in those APS film canisters. Kept the empty box for nostalgia I guess. Sits in my spare parts box.
Found a battery station pelican 1010 case with the foam cutout for the cr123 cells (rayovac 123s are still from a while ago also.)
    396 KB
    412.1 KB
    312.8 KB
    392.6 KB
    490.2 KB
