Oldstyle steampunk in copper
petergunn
An old R2 P60 drop-in + copper pipe + Romex - assembled using simple hand tools...
5-mode driver boost/buck driver - the spring off the drop-in helps secure the connection between the pill and the body
Head lights up through the clear epoxy used to bond the glass lens and wire bezel
I was going to gift it (down to earth friend thats not into shiny/gadgets) but now I'm thinking of keeping it for myself :D
-PG
3/4" water pipe - got the idea when I noticed the outside diameter was very close to the P60 outside diameter and the pill was a close match for the inside diameter :)
The sprint off the drop-in is a tight fit inside the pipe, but the pill wont fit with the spring attached (unless you grind it down a little which would be easily done - I have a modified MC-E drop-in that did fit with the spring attached).
Fantastic mod!
Very steampunk and retro-cool while having a modern emitter.
That is nice!
Now you need some goggles, a bowler hat, and a waistcoat.:thumbsup:
Kevin
The whole steampunk thing is a little weird, and too H.G. Wells for me... yet there's a sense of romanticism about it that I like, and am drawn to. Definitely something aesthetically appealing about it when done well.
Nice mod. Looks cool.... and nice frickin' beam for a generic drop-in! :thumbsup:
