jon_slider
- Joined
- Mar 31, 2015
- Messages
- 5,164
You might want to do some research prior to swapping the emitter - This light has a mag control and changing the led may render it completely useless. There are several threads on this exact subject here on CPF..
I started the threads you refer to. But I often disagree with my younger self.
I now carry an RRT-01 modded to 4500k N219b.
what I have discovered, is that I intuitively offset the lumen drift, by dialing the dial up and down in small increments to obtain my "just right" illumination
In fact, last night I did a test with my HDS and RRT-01. I shined each across my dark living room, to illuminate a painting to my visually "enough to see" but not too much to drain the battery too fast.
To my surprise, and gratification, I was able to set both lights to within ONE lumen of each other. Because I set them on my light meter, AFTER I had dialed to the illumination I found pleasant.
Even more suprising, and gratifying, my RRT-01 was holding very steady, by the time I put it on the light meter...
soooo... false alarm, there is not really a problem with the 50% change in brightness that my magnetic rotary CAN exhibit, both before and AFTER an LED swap. Because I intuitively dial up and then down a little, which clips the excessive drift to make the light a total Joy to Use
So, I renew my recommendation of Magnetic Rotaries, modified to whatever LED pleases the user.
And, a Ti Magnetic Rotary, when they can be found, cost less than a brand new Aluminum HDS.
Of course, if money is no object, and a max of 200 high CRI lumens from a small hotspot is sufficient, then HDS now offers a Titanium Rotary! That IS Bling! And it is even possible to get one with my dream LED, the 219b 4500k 9080.
Now about those 200 HDS lumens.. because they are focused into a tight small hotspot, they are potentially as bright as 800 lumens from a diffused triple.
So now, we have a problem, how to justify NOT buying an HDS Titanium Rotary.. When a Titanium Magnetic rotary is in actual use as good or better, in terms of ease of use, CRI, and EDC utility.
And then there is the pocket clip issue to consider. HDS Rotaries do not have a good Bezel down pocket clip option imo. There is a way to put a clip under the bezel.. but it is not factory approved. By contrast, the magnetic rotaries have very nice clips, and they are deeper carry than any standard HDS clip, with the exception of the Fugly Universal Clip, that I wont even consider.
After all that, I renew my recommendation to the OP, to try to locate a Ti Magnetic Rotary, and mod the LED to High CRI. The specific Ti magnetic rotaries to be on the hunt for are Jetbeam TCR-1, Niteye Eye 10 TiC. These are 18350 friendly. If 16340 is sufficient, then the Sunwayman V10R Ti is a candidate.
Good luck with the shopping!
