Other Lithium Battery Sizes
eav2k
I wanted to share some larger battery sizes I found in search of a pack for an electric bicycle. This may have been posted before, if so I apologize.
Li-Fe-PO4 Rechargeable: 42120e (M size) Cell 3.2V 10 Ah, 50A Rate at $36.95 ouch.
32600P (D size) Cell 3.2V 3000mAh, 60A Rate, 9.6Wh at $19.95, which is also a Li-Fe-PO4 cell.
32900P ( F size) Cell 3.2V 4.5Ah, 90A Rate, 14.4Wh at $34.95, which makes the M sized cells look like a bargain.
Next is a huge cell, 3.2V 60 Ah, 3C Rate (192 wh) at $119.95. This is what you use to power that array of 100 MC-E leds.
Total Power solutions has prismatic cells ranging from 3.2V 8Ah LiFePO4 Rechargeable Battery at $27.99 all the way up to 3.2V 200Ah LiFePO4 cells for $699.00.
These were just the single cells, some of the available battery packs were even more interesting. For instance this 12.8V 20Ah ( 256 Wh, 60A rate) pack for $249.95
