* P60 Flashlight List {host}
BTW new vesrion of an older host
SmallSun ZY-C73 Cree Q3-WC 3-Mode 150-Lumen LED Flashlight with Assault Crown -
DX 24354
UltraFire 504B HA-III Cree R2-WC 5-Mode 220-Lumen LED Flashlight DX 24200 & 24201
DX 24354
got it,
thanks..:D
of course...I only copy pasted the DX title...
at the price and the way it shines I would not be shocked if it was only spray painted....
wow! that is a killer.....
i would like to know if the tailcap is copatible with the CL1H
Anyone care to speculate on what the performance would be like on the Javelin? I would love to own a 2xAA P60 light, but not if the performance was worse then a dedicated 2xAA light (LD20, D20 etc). Would it be difficult to find P60 drop-ins that would work well with 2xAA?
The only data I have seen for drop-ins that will work with 2xAA are from Solarforce.
I believe it was reported to have about 1 hours runtime on high.
Solarforce and Dereelight both have P60 drop-ins that will work with 2xAA.
I just received the Ultrafire 504B in the mail Friday and here is my initial impression:
The flashlight is heavier then I expected, the battery tube and head are made of thicker metal. There is good heat sinking enough to for an MC-E P60 drop-in on high. The threads are larger than on my Deree CL1H and are smooth. The battery can be taken out through the tail cap area or the head side when removing the Pill. My AW protected 18650's fit with very little rattle within the diameter of the tube. The tail switch is a reverse clicky and mine tail stands nicely with no obstructions from the switch. The switch moves without too much force and feels comfortable. The finish on mine is very good with no noticeable blemishes.
The lens on mine came very dirty and hazy, it took awhile to clean it but it is fine. This light might benefit from a better lens. The O-rings on the head and tail cap are not tall enough, they need to be about .5-1 mm taller to create some resistance and provide better water protection.
All in all a good host for a P60!
those would work great with an FM AA body. Im going to order one, MY GF doesnt like Lion 3.7 cells...she likes alkaline nimh etc...
With 2 x AA and the stock OP reflector, I'm measuring about 7,000 to 7,800 lux on my meter. For reference, the EagleTac P20A2 with the SMOOTH reflector (I think it was the brightest 2 x AA light to date) measures about 6,200 lux on the same meter. With the smooth reflector installed in the Javelin, I'm getting about 9,000 to 9,500 lux! The addition of the ext tube (3 x AA with SMO refl.) resulted in 10,500 to 11,000 lux! :D
Does anyone know whether or not the "Police" branded light at Lighthound is P60 compatible?
http://www.lighthound.com/Police-Chinese-Flashlight-Black-ON-SALE_p_6-1548.html
well it is!
did it last night..a P60 module will thread im the place of the Xenon bulb assembly, but it has to either have the right geometry of some material removed form the pill...(see elsewhere on this thread)
The problem is that a P60 wont fit....but a cree optic (23mm) (from DX or KD) will easily go in the head if you remove the reflector..so you screw in the pill, place the optic in the LED and top-off with the bezel....
Presto...damn I was lazy last night and got no measurments or pics..maybe next week.
Edit 21/11
here is a pic of the mod....
CAUTIOn....the brass pill dimensions are critical..By this I mean how high it will sit on the body. Other wise thre will be some dead space....in that case I suggest using a 1,5mm+ O-ring between the optic and Lens
I can confirm that the Cabela's CR123 powered 6V and 9V lights will accept Gene Malkoff's P60 drop-ins. The Malkoff drop-ins fit my lights perfectly; they don't rattle; and the upgraded output amazes those whose life experience does not yet include exposure to real lighting tools.
If you are a bit creative the Streamlight Twin Task 1L and 2L can be P60 hosts.
Takes drilling and tapping tail for Kroll and gutting the lights. They weren't worth much as stock anyhow.
Dave, what specific Cabela's model,..is it the XPG N-series?
LG&M
make an advanced search for it....and in youtube too..
the Stryker has a narrower drop-in socket....so either you will have to thindown the drop-in (reflector) or open-up the flashlight socket...
