P60 fried?
nilfire77
My SF C2 with stock P60 module was originally working with the SF batts... Until i popped a set of freshly charged 3.0V RCR123 into it. It flashed for a split second before going dead. So question here is... Where did it go wrong? :(
Just for your knowledge...CR123 cells in your SureFire sag to around 2.5v under load.
I <<POOFED>> my very first P60 in exactly the same way. Some companies advertise them as replacements for CR123 cells--but they are not! You can find a Lumens Factory bulb that will work with your rechargeable batteries.
P60s can be had on CPFM for less than $10 if you shop around. I'm thinking of getting more P60s as time goes because people have been taking them out and putting in "P60" drop-ins. They are actually designed to operate at 5.5V and function very well at 5V, draws about 1.1A. Makes a pretty nice work light connected to an Iomega switcher, when it goes :poof: well... another $10 puts it back in its place. For lamps with equivalent outputs, the prices on cpfm are hard to beat
What are est. volts that a charged RCR123 puts out?
RCR123's are anywhere up to 4.2v off the charger as mentioned, but the 3v RCR's are about 3.2 hot off the charger, and may have less sag than the primaries, so could be 2.8 under load or more
