Ok I finished my 3c p7 CSXPI and powering it with nimhs. I'm also using the heatsink from fenix-store. The batteries aren't even fully charged and the current is 4 amps at the batteries! After running for 10 seconds the color has shifted to a noticeably blue tint and dimmer. The dome of the led is too hot to touch at 10 seconds.
I read somewhere when using arctic alumina the object being epoxied must have pressure applied to it for an hour before pressure is removed. I guess my question is do you have to apply pressure the entire time on the led when waiting for epoxy to cure? If so how do you guys do it.
If the problem isn't epoxing the led to the heatsink than what could it be?
So far the led isn't damaged yet, everytime I turn the light off and let the led cool, when turned back on brightness is normal again.
I don't want my entire project to be a failure. Please help.
