P7 how to clean lens
andersonEE
Erie, PA
Hi, I bought a P7 on a star from DX awhile back and had it sitting on a shelf collecting dust (I know...shame on me). How do I clean off the lens. The lens is not glass, it's kind of gummy and soft so I don't want to use any chemicals that would make it foggy or scratched. I could just run it under water, but I'm not sure if that would get inside and ruin it.
Any suggestions?
- Thanks
Any suggestions?
- Thanks
I want to say use a soft cloth or pad/tissue paper with rubbing alcohol... I've used that before but I can't remember if that was on a glass or silicon dome. I've got an MC-E I should clean up though so I'm interested to see the responses to this.
The datasheet states:
This device should not be used in any type of fluid such as water, oil, organic solvent and etc. When washing is required, IPA(Isopropyl Alcohol) should be used.
I dunno about what kind of cloth/tissue should be used though.
I bought a p7 off of DX and it came with a smudge on the actual gummy surface of the LED, I used a very fine microfiber to lightly rub off the foreign substance.
I've used iso alcohol & a costco freebie lens cloth and it worked well. Q-tip dampened with alcohol has also worked, followed with the lens cloth.
Just be careful not to dislodge the lens, some are not too secure.
I use antistatic lint free wipes & 99.9% isopropyl or denatured alcohol. Cotton swap will do the job just fine too.
I've heard this but I've never had the dome fall off on any Seoul P4, P7, or P9 even pushing on it hard. I find Cree XR domes to be the ones that fall off easy.
Had it happen on an upgrade pill from Lumapower, q5 cree xr-e(?).
The adhesive was all over the top of the silicone dome and popped right off to a delicate wipe. New pill sent the next day.
