I found the threads on salvaging 18650's from laptop batteries lovecpf So I raided the battery recycling box at work today and got a couple.
One was a modern HP battery, and had 6 samsung's labeled "IRC18650-22E". All 6 were at 3.79 to 3.82v - Yeah!
The other was an old Dell. It had 9 unlabeled 18650's that were wrapped in paper. 3 were 0.0-0.01v. The other 6 were around 3.6 +/- a bit. The paper wrapping is just sitting on the battery. I can slide them off, which makes me a little nervous. Their shells also seem to be a little thinner because they dented slightly when I pried the tabs off.
I'm thinking about either putting some glue on the paper to hold it on, or getting some heat shrink to replace the paper with.
What would you do?
What would you do?
