PD30 problem
asolo
Well, I searched but couldn't find the solution to my issue. With my PD30 head tight I click on the light and it turns on. Click it back on, no light. Click it again, there is light. I tried new batteries with no difference. I also noticed when the light would not come on normally, the LED would be flickering slightly (very low output). Got any quick fixes?
Thanks!
I guess to sum it up-It doesn't turn on after 2 cycles of the push button. Click it again after the malfunction and it works again.......
Yep I have a LD10 that does the same thing, it's the switch I just have not been able to get the dang retaining ring out no matter what I do.
have you tried tightening the brass ring on the inside of the light?
