Beacon of Light
- Joined
- Dec 9, 2005
- Messages
- 2,122
Hi guys some of you may have followed the AAA run-time test I did in three parts in the main LED Flashlights forum. I figured I'd post it here. All lights used Duraloops (Duracell NiMH rechargeable LSD batteries) with a refresh cycle on my Lacrosse charger. Most were slightly higher than 800mAh off the charger, but all cells were fairly consistent.
Peak Matterhorn 3-LED SP 11+ hours @ .99v (light dim)
Peak Eiger #3 15+ hours @ 1.14v (light dim)
Peak Matterhorn 3-LED HP 15+ hours @ 1.16v (light dim)
Peak Matterhorn 1-LED HP 16+ hours @ 1.16v (light dim)
Peak Matterhorn 1-LED SP 37+ hours @ 1.07v (light dim)
Peak Eiger #0 37+ hours @ 1.10v (light dim)
Peak Eiger #Subzero 37+ hours @ 1.11v (light dim)
I think after the test I have more questions than I did before I ran the test. Here goes and feel free to chime in if you have any thoughts or answers.
1) Why would the High Power Matterhorn 3-LED run longer than the Standard Power Matterhorn 3-LED by quite a big margin? Also the HP light was brighter than the SP for a majority of the time as well. The remaining voltage in the HP was also greater. I spoke to Bob @ RMSK and he just said due to LED variances. I just figured this is too big of a difference to just say LED lottery. Any thoughts?
2) Why would the older Matterhorn Standard Power last just as long as the Eiger #0 and Eiger #Subzero? The new Eigers with XP-Gs are supposed to be more efficient but that wasn't realized by this run-time test. Any explanations on this?
3) The differences between the Eigers themselves where I was expecting much higher run-time with the #Subzero and I didn't see that at all. The #Subzero was dimmer than the #0 which was expected but I figured the #Subzero with a 80ohm resistor (compared to the regular #0 with a 56ohm resistor) would have approx. 1 1/2 times the run-time of the #0, or don't resistors work that way?
Thanks and feel free to ask questions as I have learned a lot just doing the test.
