Pen Size Flashlight?
Rich219
I just saw a pen pen on my desk and thought that it would be crazy cool to have a flashlight inside of a regular pen body.
I know I could just buy one of the pen size flash lights but how hard would it be to custom build myself a light that I could fit into a pen body?
AAAA are about 6mm diameter - you could fit two in a pen.
You could buy a 1.0-3.0 volt driver on a 17mm disc and totally rebuild it to fit inside a pen !!!!
Really!
I know nothing about building a custom flash light but would love to do this as a project.
So please forgive my newbness but what is a volt driver and what is a 17mm disc?
Not sure why you'd want to use a 17mm disc on a 10mm pen unless it was to harvest the components, and even then it'd probably be easier to get the components separately:
For a single-cell AAAA light, you could use the Joule Thief circuit (see http://www.bigclive.com/joule.htm) or a ZXLD381 chip and an inductor (see http://www.candlepowerforums.com/vb/showpost.php?p=2954378&postcount=4).
If you're willing to use a stack of 3 silver/alkaline button cells, you could direct-drive, possibly with a small current-limiting resistor to avoid burning out the LED. SR41/LR41 is the smallest diameter with useful capacity IMHO. You can get watch batteries that are smaller but they won't be able to light the LED brightly or very long.
For a single-cell AAAA light, you could use the Joule Thief circuit (see http://www.bigclive.com/joule.htm) or a ZXLD381 chip and an inductor .
A ZXLD381 will drive the LED up to 55mA. I've been looking at a "1-cell to USB" converter PCB to achieve up to 500mA LED drive.
That's not my experience - I find it far easier to get non-standard SMT parts by buying a known working module and redoing the mechanicals.
I needed a small 4x7135 driver - so I cut a 17mm PCB in half.
Since I have absolutely no idea where to begin but really want to do this project can anyone direct me to a tutorial on what is needed to build a custom light?
How bright could I make a light this small?
Using a 5mm LED and alkaline battery, maybe 10 lumens.
Using something like a Cree XP-E and a lithium battery, you could probably exceed 70 lumens.
