Any particular reason you guys aren't just using the glow paint? It's made from the same material and has the same glow/brightness rating, I'd think it'd be a lot easier to just paint the interior grooves..
I was wondering if any of the people who have used the epoxy and glow powder combo could let me know how much glow powder they actually used for particular projects. I have the epoxy, but am wondering how much powder to order. How many tail rings could I make with say 1 ounce of glow powder?
Thanks.
Here's my D10. I really like the technical look of the piston and the glow dots.
I used a drill press. It's important to center punch very accuratly. There is a tiny little "bump" in the middle, which has to be removed first. I drilled about 3 mm deep and the hole is 6,5 mm in diameter.
I used epoxy with a relatively thick viscosity which cures in 5 minutes.
If the epoxy is not mixed as directed, it may remain sticky for the quite some time. It will eventually harden though. I like the idea of the liquid polymer clay though,
yaesumofo:
Could you post a brand or more details about what you use.
damn, that looks goooood:thumbsup:Gorgeous . What did you use to bore out the hole in the piston?
