Peter hauk was one of the founders of laser products: "Humble as it may be, the common light bulb is not at all common once SureFire engineers inject their cool science. Technically known as a lamp assembly, not a "light bulb," SureFire incandescent light sources are custom designed, manufactured and tested to an incredible degree.
Dr. Peter Hauk, who holds a Ph. D. in quantum chemistry, oversees all of SureFire's lamp development programs and his comprehension of the science of light is a constant source of bewilderment— not to men- tion confusion— to his less-intelligent co-workers, like the hapless copy- writers of this catalog.
We'll try to distill Dr. Hauk's encyclopedic knowledge of photometric principles down to a Google-sized bite. There are really three fundamen- tal reasons why Dr. Hauk's lamps are so bright and SureFire's beams are so flawless.
First, the hotter you run the tungsten filament, the more light you get. Dr. Hauk specifies that our custom-wound, pure tungsten filaments run at a color temperature of 3,150° Kelvin.
Such high filament temperatures are only possible within a high- pressure, pure Xenon gas atmosphere. Dr. Hauk specifies a 100 percent Xenon fill and, in some models, adds a halogen cycle to enhance the life of the filament. A family of elements, halogens form a sort of transfer sys- tem for collecting tungsten molecules that have boiled off and migrated
to the lamp wall and redepositing them on the tungsten wire, where they boil off again in an ongoing cycle, the halogen cycle.
Dr. Hauk's lamps also operated on the principle that the more power you put in, the more light you get out. Practically speaking there is no more powerful source of energy for a flashlight than a lithium battery.
Unlike cheap offshore-made batteries, SureFire's American-made batteries come with two safety devices built in. One is called a thermal shutdown device and it serves as a self-cancelling heat safety in case the lithium battery gets too hot.
A lithium battery generates significant heat when its energy is sucked out too rapidly. Without a thermal safety device, the battery can heat to dangerous, even explosive, levels. Please note that all American-made lithium batteries come with effective safety devices, but offshore-made batteries fall short. There have been problems with offshore-made lithium batteries. If you choose not to purchase SureFire brand batteries, please buy an American-made battery, for your own safety.
A third principle is that the more perfectly shaped the reflector, the better the light is focused into a lovely beam. Dr. Hauk designs our reflec- tors to create an intensely bright center spot and a soft corona of periph- eral light, with minimal wasted light. He tests every lamp from every man- ufacturing lot in his Black Lab, a specially constructed testing center with matte black walls and ceiling.
SureFire reflectors are a perfect parabola with a special wave-like coating to increase the surface area. The custom lamp assemblies are then centered to exacting tolerances in the reflector, again maximizing the beam's quality.
Given the amount of testing, verifying, experimenting and innovating, it's little wonder that SureFire offers almost 50 different incandescent lamp assemblies, ranging from 15 lumens to 500 lumens. Of course Dr. Hauk could take the rest of this catalog to explain exactly why SureFire incandescent lamps are so astonishingly bright. Suffice it to say, there's a lot of cool science at work."
