So, the diffuser is only as wide as the main LED? I thought this was just the tab that you used to slide a full sized diffuser over the entire lens.The BAD
Red LED is overpowered and kills night vision. this could be remedied with a diffuser like the normal LED.
The Pulse Width Modulation on the low setting is the WORST i have ever seen.
3xAAA ... 'nuff said.
No Rubber O-ring
If you're concerned over the "plastic on plastic" from a durability standpoint, you needn't be. I've had my old model Tikka XP for somewhere in the neighborhood of 4-5 years, use it all the time, and the ratchet still works fine.The KNIT-PICKY
Plastic on plastic ratcheting/ tilt.
Lack of last mode memory
The low battery light seems oddly placed in the front. You cannot see it unless the light is shining in your face.
I agree that the old model Tikka XP was possibly a better design. For each improvement they made on the new model it seems they removed a feature that the old one had. I actually purchased two of the old model lights and did the P4 mod for this very reason. As long as the old model was out and for as much hoopla as Petzl made about the 2009 lights, I'm afraid it may be a long wait to see any fixes implemented.OVERALL
I'm still waiting to see how the supplied batteries perform before posting photos, but I'd say this light could use some improvement, While it is definitely smaller than the previous Petzl Tikka XP, I think the previous version might have been a better light. The low mode is bright enough for reading but the PWM may be too low of a frequency for those sensitive to flickering lights. The Red LED will probably remain a novelty until I can find a way to diffuse the light.
The plastic diffuser covers both LEDs (white and red), but it is clear plastic over the red LED (except a very small area at the edge nearest to the white LED).So, the diffuser is only as wide as the main LED? I thought this was just the tab that you used to slide a full sized diffuser over the entire lens.
