Photon Freedom LED Identification
dougmwpsu
Hi all,
I just received a Photon freedom and Fenix e01 in the mail. Very exciting! I'd like to try and identify which LED is in the Freedom. How can I tell if I have the newer, brighter Nichia GS LED in the Freedom? Compared side by side, the Freedom with fresh batteries is about the same brightness, maybe a hair brighter than the E01. if i put the freedom on it's lowest brightness, I see a rectangular light block under yellow phosphor inside.
Thanks for your help!
Doug
There is only 1 lumen difference between the GS and DS.
If you see a rectangular shaped die then it is definitely a GS.
As the Freedom was one of the initial lights to start using the GS, I have to think it's a very high probability it has the GS. Having said that my Freedom on new batteries is way brighter then E01. My E01 is maybe as bright as a CS.
