Rothrandir
here is a pack i made for the arc4, intended to use a pila 150s battery.
i've been wanting to do this since before i even had an arc4. due to the amazing kindness of frenchyled (hi russian /ubbthreads/images/graemlins/wink2.gif), i now have one! /ubbthreads/images/graemlins/grin.gif
with a higher voltage, and decreased internal resistance, the pila batteries are a wonderful thing indeed! and with a converter such as the one in the arc4, they really shine.
i chose to use a 150s because it was only a bit longer than a 123, and as it turns out, the form factor is much better than the standard arc4. as you can see in the second picture, it fits my hand perfectly.
this pak is only a proto, because i wasn't paying attention, and faced it a little too short /ubbthreads/images/graemlins/frown.gif as a result, the battery goes in too far, making the tight tolerances of the tension not work properly /ubbthreads/images/graemlins/frown.gif
it can turn on and off, and change brightness levels, but i can't get into the advanced menu's /ubbthreads/images/graemlins/frown.gif
being too short anyway, i didn't take a whole lot of care as i finished making the thing, as it will only last long enough to make another one /ubbthreads/images/graemlins/tongue.gif
as a result, the knurling isn't quite perfect, and the top threads are a little shallower than they really should be.
not sure how i'm going to do the knurling on the next one. i like the little groove on the top for the clip, but i'm not convinced it looks quite right.
i've got a pila 168s in my e2e 5wpr, and now a 150s in an arc4, these things really rock! /ubbthreads/images/graemlins/buttrock.gif
when the 2-123 pak comes out, i hope it will work with a 168s, and maybe eventually peter or someone might look into a pak for the 150s.
i can't find the stupid brass spacers for my pila charger, so i've been running off a dead 150s for the past while, but as soon as i can find them to charge the battery up, i'll do a runtime test on level 1 /ubbthreads/images/graemlins/smile.gif
i'm anxious to see how the efficiency reacts to the higher voltage of the pila...
and i might as well go out and say it here, both the arc4 and the pila are some of the best flashlight related products i've had the pleasure dealing with! i can't say how thrilled to death i am with both of them. major thumbsup to peter gransee and jonsydneyb /ubbthreads/images/graemlins/thumbsup.gif
