**PIX HEAVY*** 28 Beams & Tints from LED flashlights
EngrPaul
PA
I grabbed the lights I had sitting on my bookcase and took some pictures against a white wall.
Please note: All pictures were taken with locked zoom and color balance on a tripod.
Although the light was put on it's highest setting, the exposure was set by the camera for each picture, therefore don't compare relative output.
This gives you the best chance to compare tints and beam profiles. Have fun.
***5mm Nichia Emitters
Fenix E01
Proton Photon I (6 White LED's)
***Luxeon V Emitters
Nuwai TM-301X-5
***Seoul P4 Emitters
Fenix E1 Upgraded with SSC P4 USV0H
Ultrafire WF-601A Upgraded with SSC P4 USW0H
Lumapower LM-301 Upgraded with SSC P4 USV0H
Duracell Daylight CR123, Narrow
Duracell Daylight CR123, Wide
***Seoul P7 Emitters
Trustfire P7-A2
***Cree Cool White Emitters
Huntlight FT01 Cree P4 OP reflector
Ultrafire WF-606A1 Cree P4
Raidfire Spear Q5 OP reflector
Nitecore Extreme Q5
Nitecore D20 Q5
Trustfire TR-801 Q5
Fenix P1D-CE Q5 OP reflector
Fenix PD20 Q5
Lumapower D-Mini with Q5 upgrade SMO reflector
Lumapower MRV (Gen 1) Cree P4 SMO reflector
Lumapower MVP 3X Cree Q5
EagleTac P10C2 Q5
***Rebel Emitters
Fenix P3D RB100 OP Reflector
***Golden Dragon Plus Emitters
Nitecore D10 Osram Golden Dragon Plus
***Cree Neutral Emitters
Fenix TK20
Dereelight C2H 5AQ3 SMO reflector
Dereelight DBS V2 5AQ3 OP reflector
Jetbeam Element E3P 5AQ3
Jetbeam Element Military (Jet-III-M) OP reflector
Wow, thats a nice collection you got there. Do those neutrals really look that warm?
The camera tends to provide much more color saturation than my eyes can detect. Used alone, the neutral emitters appear "peachy" white to me. On comparison to other LED beams side-by-side, it looks yellowish. The camera makes them look orange/gold for some reason.
WOW.......... those are some shweet beam shots! thanks for posting them.
you need more flashlights dude....
I have been searching a long time to confirm whether the 4 watt LED Daylite 160 uses a SSC P4. I know someone had stated a while back that the 3 watt 80 lumens model used one. I am tying to contact a technical person in Duracell.
-Hitec-
-Hitec-
I can visually see that it's a SSC base, much like the hundred or so P4's that crossed my bench. But as for the dome I can't see it to confirm a P4 die.
I did some current measurements and found the driver of the Daylite123 consumes only 3.2 Watts from the cells. That means there's something less reaching the emitter.
