No overclocking computer processors was where I was coming from, and what I know of binning is only related to that.
I was asking if LED binning is the same in that, a different batch of LED's are brighter (run at stock specs) then a previous or lesser batch of the exact same LED light.
For computer processors you just cant raise the Ghz as high on a lesser binned processor. So I was just making sure that the word binning was being used in the same way, to signify what batch of the exact same thing, that they were from. I do not think I would run an LED brighter than normal cause I'm not that good yet and I would probly kill my expensive LED lol.
LED's are not binned on what they can handle.
They are driven at a set safe current, and the resulting voltage drop, output intensity, and chromaticity are tracked to determine which "bin" they get tossed into.
A better analogy would be the way flash memory is tested, not the way processors are tested.
They are driven at a set safe current, and the resulting ... output intensity, ... are tracked to determine which "bin" they get tossed into.
Most current power LEDs are rated at 350 mA. That is similar to saying all CPUs are tested and rated at 1GHz.
The LEDs are sorted into what they can do at 350 mA. This is similar to sorting CPUs that can run at 1 Gz into single core (Pentium, Atom); dual core (core dual); quad core (core 2 dual) bins.
... and chromaticity ...
CPUs do not feed data out in colours but I'll try to find an analogy. White LEDs are a phosphor on top of a blue (or violet or UV) LED core. The bluer LEDs have less phosphor, the warmer LEDs have more phosphor.
So a WA colour bin (extreme left of ElectronGuru's chart) has almost no phosphor. That is like a Celeron with no math chip nor internal cache.
A WC/WD/WG/WH colour bin is like a Pentium1, internal cache, math coprocessor.
A 5A colour bin (warm white, next chart) is like the latest CPUs with internal cache, math coprocessor, and graphics processor.
... resulting voltage drop ...
There is no equivalent analogy in a CPU as Vf an analog function. Lower Vf allow more current through from a fixed voltage source producing more light. It may allow too much current through burning out the LED.
Drive levels
Actual brightness levels in an LED of any one bin are controlled by current drive level. Similar to processor power controlled by clock speed.
There is one major difference. Going from 350 mA to 1000 mA (3X) will only increase the brightness 2X (80 to 160 lumens for an XRE P4 bin). Going from 1GHz to 3GHz will increase processor power 3X.
LuxI - 350 mA max. Overdrive not recommended.
LuxIII - 700 mA max. 1000 mA overdrive known.
Cree XR-E/SSC-P4 - 700 mA max. 1000 mA allowed on some chromaticity bins. 1400 mA overdrive known.
Cree MC-E/SSC-P7 - 2800 mA. Overdrive not recommended.
Cree XP-G - 1000 mA max. I would not try to overdrive it.
I do not have any info on the Cree XP-E or Luxeon Rebel.
