I have a Nuwai Q3 modded with a FluPIC and a SSC P4 USW0H (with the stock "heatsink" and a cheap mineral glass lens).
I was generally pleased with it: the stock reflector is a good fit for the SSC and it gives a nice white beam with a well defined hotspot and smooth transition to usable spill.
Well... I *was* pleased with it, until I compared the beam with a friend's L1D-CE (textured reflector - not the Q5 version). Note: he bought it following my advice
The hotspot on L1D CE is brighter than my Nuwai, while the spill seems to be the same (it's hard to judge because the beam of the L1D has some rings).
Judging by the specs and the fact that the Nuwai is driven by RCR123 (while my friend had an Eneloop in the L1D CE) I expected the Nuwai to be brighter than the L1D-CE.
I checked the FluPIC operation and the highest possible setting for the "User brightness level" has the same intensity as the "Max brightness" mode which it shouldn't, "Max brightness" is supposed to drive the LED at >1A.
I checked the batteries (yellow Batterystation ones with the Nano charger) and they appear OK, they come out at 4.2V from the charger and seem to hold charge well.
So, I have a few questions...
- Am I wrong at expecting my Nuwai to be brighter?
- If it's supposed to be, what should I check next?
I was thinking about a heatsink (although the light does get hot which means heat is transferred away from the led) but I don't have the skills or the tools to make a better one myself.
I would be grateful for any suggestion.
