I have been messing around with my MagCharger and the universal smart charger I bought a year ago I have been trying to get the charger to charge my Mag thru use of the craddle but the problem I am running into is because of the diode that is in the positive charging ring on the MagCharger. I suppose the charger is not detecting the need to charge because of that diode. The charger I have is this one http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=3005. Does anyone know a way around this without removing the diode? I would like to keep the diode to prevent it from shorting. Anyone have any suggestions on what charger I can use that would work? Maybe a charger that does not auto detect the voltage... I need a charger that is a smart one in the sense of detecting when the battery is full so it cuts the power off to prevent overcharging, and I also would like it to be able to charge the battery fairly quickly in several hours,1amp,2amp etc. Any suggestions....
