WildRice
not sure, i believe it was 90 sec. the fun part is mixing. when you meter out the epoxy, try to keep the two parts seperated. use a tooth-pic to mix in the glow powder into the parts, then mix them together. otherwise you wont have enough work time. apply with tooth-pic all the way around. when 360 done, hold flashlight horozontal and roll trying to keep epoxy even all the way around. I know 5min and up epoxys work better, but they take too long to set for this application.
Also, unless the target light silver colored, a white undercoat is needed. I useually use aluminum tape fitted under where I am going to glow.
Best of luck.
Jeff
Best of luck.
Jeff
