PolyStinger Conversion?
InspectorJon
I saw another inspector with a Streamlight Stinger that had a LED conversion kit with an LED emitter and new reflector. Does anyone know if there is such a thing for a Polystinger? The Terralux at battery junction says it does not fit the polystinger.
Dunno if you found an answer, but did the guy tell you it was a conversion kit or was he using the actual polystinger LED version?
From what I understand....The Stinger and Polystinger use two completely different hosts... including the head.... The conversion is strickly for the original incan Stinger
Yes, the other guy had an LED conversion kit for a metal body incan Stinger. I was wondering if anyone knows of an LED conversion kit for an incan Polystinger.
Just a quick note, i just found @ tooloutfitters.com that they have an LED conversion kit for the poly stingers, The part number is TLXTLE-ST1-EX. It states that it is for the poly stinger and it is only $35.63.
Terralux TLE-ST1-EX TLXTLE-ST1-EX LED Conversion Kit
Features and Benefits:
  • 300 lumens
  • 2-hour run time
  • Compatible with PolyStinger®
  • Electronically regulated
  • Designed and developed in the U.S.A.
300 lumen LED conversion kit that fits StreamLight Stinger®, and PolyStinger®.
