When adding the SSC, you do need to raise the emitter 0.030", unless you would like a little extra floodiness. I have tried it both ways, and did not see much of a difference. But, I was not able to compare two different lights at the same time. YMMV.
You can either modify the stock reflector, or get the MCR20-S. The MCR20-S is 0.030" shorter than the MCR20, so the copper shim is still required.
Now the down side: You need to widen the seat for the LED, as the diameter of the Seoul is a bit larger than the Luxeon. If you have a lathe, this is easy. Otherwise, a small carbide tipped grinding/engraving bit does a pretty good job. Make small passes, removing material evenly from both sides. You want to maintain the symmetry of the opening. Test fit the LED occasionally, until you get it right.
Clean the seat area with alcohol on a swab. Use some Arctic Alumina to adhere the copper shim, and check against continuity with the head. You have removed some anodizing, so it is very possible to have that contact with ground. When the shim is set, prepare the LED, and adhere it in place with more AA. Install the reflector, and seat it, and check for proper centering of the LED. Make any adjustments as needed.
Resolder the leads, and check for any shorts. Connect the ground screw, and test your work. Reassemble the light, and enjoy.
It is not too hard if you remember Murphy's law, and don't take anything for granted/leave anything to chance.
