BigHonu
Nice write up.
AA's are a nice format, but I have found that they, along with D's, are the first to go during an emergency situation. So if you rely solely upon that format, be sure to have some stock on hand all the time.
Regulated vs. Unregulated. Yes, regulated gives you constant brightness over time, and is generally preferred in normal use. However, in an emergency situation, a unregulated or direct drive light may give you 'light' over a longer period of time. Sure, brightness will decrease with voltage, but you may still have some light while the regulated light has cut out. Of course, circuit design and efficiency play a big part, but it generally helps to keep both types around.
Hope things around you are improving.
