kosPap
edit: I bumped this thread waiting for an aswer on the wiremcpcb trace thickness issue....TNX
well here are 2 question in one post...
My first concern is wire to LED thickness and PCB trace....
The thicker the wires the better, but is there a real reason for when the MCPCB trace to the LED electrical contact has a smaller cross section taht the wire itself? Or as a matter of fact the soldering pad is so small to be covered by the wire?
Next issue..wire thickness and XPG focusing...Tried many times to focus properly an XPG in a P60 module but....Using 0.30mm thick wire there was so much the reflector could go down....the cituationwas aggavated by the plastic cover melting and getting thicker at its end.
sort of made it by filing the wire/solder blob. Should I go thinner?
BTW.....No luck in finding silicon covered wire here in Greece, in small amounts and diameter...I know its "sleeve" is thinner and will gain me some room, but .....:mecry:
