Hello, all. New user of the board, new to electronics, and new to LEDs, so I apologize in advance for any stupid questions.
I did a cursory search of the forum, and didn't see anything covering this topic, so here goes.
I've got a Schmidt dynamo hub, that I've used in the past to drive a dLumotec and a homemade CREE XRE light (using Martin's Circuit 2). I would like to power a pair of lights mounted to the legs of the fork of my bike, as well as one light fixed along the bike's axis (I'll probably eventually add a momentary switch so I can flash the fixed-axis light as a signaling device, but that's another story...)
I bought a pair of MiNewt USB lamps, figuring that, since I liked their form factor, I'd just replace the guts with my own wiring. Then, it occurred to me that maybe I don't have to.
What would be the repercussions, if any, of driving a pair of stock MiNewt USB lights in series from the hub (after rectification, of course)? From what little I can tell, it appears that the SSC emitters used in the MiNewts are designed to run at 1 amp; the hub delivers a more-or-less constant 500 milliamps, so I assume I'd see less light output. Would there be any problems doing this? Anything I should plan on doing beyond the basic rectifier-and-smoothing-capacitor circuit?
Obviously, I don't really know what I'm doing, so constructive criticism and feedback is both solicited and appreciated.
Thanks in advance,
--Dan
Thanks in advance,
--Dan
